Model A1136 / 30, 60, or 80 GB hard drive / black or white plastic front
828 Questions View all
Why isn't my iPod video turning on?
My ipod isnt turning on and i tried charging it stilll wont turn on
Add a comment
1 Answer
Chosen Solution
I does sound to me like you need a new battery. You can try to charge your ipod on an AC charger and see if it will charge,but ultimately I would change the battery. Not a difficult task and not very expensive. after that you can re-evaluate. Start with the battery, be careful when you open the clip for the battery cable, pull straight up. I prefer a small paperclip bend into an L_Shape and pull gently. The connector has a bad tendency of snapping of the logic board. If after you change the battery, it should still not come on, check the dock connector for any bend, corroded or missing pins, Clean the dock connector with some isoproplyl alcohol and a toothpick (gentle!!) use a magnifying source to make sure you are not going to bend or break any pins. Hope this helps good luck.
iPod 5th Generation (Video) Battery Replacement
Score 1
Comments:
never mind about the ipod not turning it on it just is late when you press a button and it looks the screen is probaly the reason can you tell me where i can find a lcd screen under 5$????????????
by
Add a comment
Add your answer
roohullahzamani will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 239
