The Nintendo 2DS is a handheld gaming device developed as an entry level version of the Nintendo 3DS with nearly identical hardware, but without the 3D upper screen function.
186 Questions View all
Best way to remove top screen protective film?
Ive seen videos of people removing the top screens film with a hair dryer, but curious if using like an air station is better, or if theres a alternative better way to remove the scratched film I’m trying to replace. I have an air station but don’t want to damage the ds itself. Low heat? High heat and try to get it off quickly? Any help is appreciated
Add a comment
1 Answer
Chosen Solution
You could try very carefully and slowly using a razor blade. Wedge the razor blade in between the film and the screen and only push enough to get a small corner to grab and peel slowly.
Steam will also work. Always do low heat.
Add a comment
Add your answer
Cody DaGoat will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 19
