The Mac Mini family was first introduced in January of 2005.
1038 Questions View all
How Do I Repair/Mount my HD if Disk Utility does not work?
My mac mini has recently bit the dust. I did a hard shut down by holding down the power button. Since then I have not been able to bring it back. It started with a folder with a ? in it. Sometimes it sits at the apple logo, and other times it goes to a gray screen and just reboots eventually. I am running Snow Leopard, and I have booted from the install cd. I have tried running Repair Disk in Disk Utility, but I receive the following error: "Invalid node structure Invalid B-tree node size The volume could not be verified completely. Volume repair complete. Updating boot support partitions for the volume as required. Error: Disk Utility can't repair this disk...disk, and restore your backed-up files."
In the pop up window it says "Disk Utility stopped repairing "macintosh HD" Disk Utility can't repair this disk. Back up as many of your files as possible, reformat the disk, and restore your backed-up files. On the left hand side of the window I see 60.01GB ST96812AS Media, and then I see Macintosh HD offset underneath. The Macintosh HD is in light gray and is not mounted. When I try to Mount it it gives me an error and tells me to repair the disk.
My question is do you think Disk Warrior would work or something like that software? I tried to do an Archive and Install, but since the HD won't mount I can't do an installation. Is my HD dead?
Any help would be appreciated!
Sincerely,
Matt
Add a comment
New Battery = Faster iPhone
Fix Kits starting at $16.99
Chosen Solution
Disk Utility has given up on your old hard drive. Time for a new drive. You can use an external enclosure or an adapter and hook up the new drive, then use your Disk Warrior to try to recover your data. I would format the new drive andinstall a system on it before trying to recover anything. Here's the adapter I use: http://eshop.macsales.com/item/NewerTech...
Score 3
Comments:
From the size of your hard drive I would guess you have a Apple Mac mini "Core Duo" 1.66 Specs
Identifiers: Early/Late 2006 - MA206LL/A* - Macmini1,1 - A1176 - 2108
which uses a standard 2.5" SATA hard drive.
by
Add a comment
You can try Stellar Drive ToolBox, it is a great optimization utility which helps you to repair your Mac hard drive. It has volume repair utility which has awesome functionalities.
Comments:
Always nice to give a link on an old answer like this.
by
Add a comment
Add your answer
matt will be eternally grateful.
Past 24 Hours: 10
Past 7 Days: 67
Past 30 Days: 345
All Time: 10,964
