Revamped version of the iPhone 3G with faster processing speeds. Repair of this device is similar to the 3G, and requires simple screwdrivers and prying tools. Model A1303 / 16 or 32 GB capacity / black or white plastic back.
1960 Questions View all
How do I replace the ribbon for power button?
So I found the guide that goes all the way up to removing the ribbon but how do I change the housing to the new ribbon and reassemble it?
Cheers,
Josh
Add a comment
1 Answer
Chosen Solution
I just did this last night (although it was up/down volume pressure pads that were broken) and I followed the guide below. The bit I needed to change includes the volume, mute, headphone jack and power button. It's all one peice of cable.
I got my cable and tools off eBay for about £8. To change the hardware on the cable you just pull the old one off and stick the new one on. then just reverse the steps in the guide below to put i back together.
iPhone 3G Volume Button Replacement
Add a comment
Add your answer
Josh Skrzelinski will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 2,024
