Released November 2020, the PS5 console features vastly upgraded visuals and an innovative new Dualsense controller. The space-age black-and-white color scheme is a noticeable departure from PlayStation designs of the past.
My ps5 won't let me play PS5 games and I get an error (CE-108255-1).
My ps5 won't let me play PS5 games and I get an error (CE-108255-1). it lets me play PS4 games but not ps5 games. i have done every possible thing in the book to fix it and will not stop giving me the error.
Score 2
2 Comments
Did you fix this issue I’ve seen it in multiple times and everyone they send back it has the same problem
by
Did you fix this issue I’ve sent it in 3 times and they send it back with the same problem
by
Add a comment
Most Helpful Answer
Unfortunately, CE-108255-1 errors are the start of something more serious with your PS5. Rebuilding the database/cache might help, but a full fix will require either replacing the SSD, or SSD controller. Have a watch here - https://www.youtube.com/watch?v=0sopRWoc...
Score 2
2 Comments:
No software solutions work, unfortunately - rebuilds, etc.
I expect it's a chip. SSD or SSD controller seems reasonable. Any idea why either of those would cause PS5 to fail but not PS4? Seems like a bad SSD would cause general failures...
by
Watched several videos and posts about this error code. Most cases were solved by send hardware to Sony and replace motherboard or power supply.
by
Add a comment
Have you chosen your Ps 5 system as the main one in the console settings or Ps App? For me it looks like you still have your PS4 system as the main so this is the reason why you can lunch only PS4 versions of the games.
Score 1
1 Comment:
I don't own a PS4, unfortunately, so I don't think there's an authorization issue like that. If it was, it should just flat refuse to boot the game at all. In this case, it boots the game and then crashes somewhere during the first few minutes of play...
But that was a good idea, thanks!
by
Add a comment
this is what i found searching up your error code on the play station website:
"if this error occurs after launching a game, delete the game in which the errors occurs in from settings>storage and reinstall the game." have you tried uninstalling the PS5 games that are having this issue?
"Start your PS5 in safe mode and perform "5. rebuild database .".
if these fail, backup your ps5 on a usb drive or something like that with enough space to do so, and reset your ps5.
Add a comment
Hi
I’ve had the same issue, bought the console from launch, so had it just over two years now. I had it looked at by a tech engineer and they’ve essentially said the graphics card is damaged, so it will play lower resolution PS4 games as they are less demanding on the system. Unfortunately, the graphics card is part of the motherboard and can’t be replaced, Sony won’t even be able to fix it. I have asked the retailer to replace my console, which they of cause refused to do as it’s out of warranty, but have agreed to a pro-rata refund. The alternative option is to use Sony’s out of warranty service, which costs £240, but they guarantee to give you a working console- if they have a refurbished one then that’s what you get, otherwise they provide a new one. You may need to get someone to independently look at your console and investigate the cause of your fault, but I’ve seen plenty of cases online exactly the same as mine.
3 Comments:
Thats not true! PS5 uses an APU if they claimed the graphics card is damaged then ps4 games wont work either! The console wouldn’t even pass POST when you turn it on you will get the constant blue light blinking. PS4 games plays @1080p same as with PS5 games unless you change it in the game settings so whatever tech engineer told you that bullshit needs to go back and retrain the CompTIA A+ certification.
by
@haktendo
What would you recommend? IS there a solution for this problem? I still experience this every time I attempt to play the "PS5" version of a game.
by
Rebuild databases, do a clean install of the system, open it up completely all the way down to the motherboard to see if the Liquid Metal needs to be re-spreaded. You can remove that Liquid Metal and replace it with old fashioned thermal paste (that’s what I did with mines). Try not to expose the liquid to any circuit on the board or that’s it! If that doesn’t solve your problem take it to Sony for a repair or replacement.
by
Add a comment
Rebuild the database of your PS5 as corrupted data can cause this issue. Here's a guide that you can follow to know more about this issue and fix it-
How to Fix PS5 CE-108255-1 Error? - Tech Reloaded
Add a comment
Try rebuilding the database as corrupted data can cause this issue. Heres's a guide I would suggest you to follow to know more about this issue and fix it-
Add a comment
What about your trophies I know your on ps5 but on ps4 I have at least got all my games that I currently have at 1% if you have any trophies at 0% delete them or play them until you get 1% that fixes an error code so if system reads there's an error all your games are at 1% it's not your games and not the system it will be the current game you download
Add a comment
I have similar pattern on a Launch PS5. PS5 games crash but PS4 games are all fine. Within a random amount of time of booting any PS5 game (disc or digital) I get a CE-108255-1 or a CE-100996-6 error. Will play movies and any PS4 game fine. No PS5 game of any kind works - neither a 100mb 8bit platformer nor Cyberpunk. PS4 versions of identical games load fine.
Have done every version of database rebuild, usb etc. etc. All the copypasta "ReBuiLD your DatAbAsEs" advice is completely useless. Sony's customer support was a bot that kept forgetting what it had just said.
Tried wired/wireless and different network. Tried anon account. Added an NVME drive and booted a game off of that. Tried all possible graphic settings and switches.
Have gone through many system software updates since it started and none have resolved it.
Took it into a shop and had them professionally tear it down and redo liquid metal. They also swapped PSUs to see if it was something in the power supply. No dice.
The idea it's overheating is incorrect: it happens immediately on startup. It may have been a heat issue at one time, but now there is a damaged chip somewhere. Seems likely it's the APU.
I have had five different shops refuse to repair it or troubleshoot it.
Very frustrated. Will be my last Sony console, and I had them all.
3 Comments:
Have you tried to choose your ps 5 console as the main console in the PS App?
by
@nomaddmf It's the only sony console I have currently - all the others were deactivated.
I expect an authentication-type failure would cause the app to refuse to launch at all, right? Crashing 2-5 minutes in seems unlikely to be an authentication problem.
Good idea, tho - may help someone else!
by
I have exactly the same problem, can't load any ps5 game. I get a crash in 2-5 minutes.
by
Add a comment
I have this same issue, my PS5 got knocked over by one of my dogs and it's lost the ability to run PS5 games ever since.. black screen, monotone beep, error code blah, blah, blah. The only thing that I've found that somewhat works; and it's not a solution mostly a crappy band-aid, I'll turn my PS5 on and click into whatever PS5 game I want to play, then I'll go occupy myself for an hour and I've had like a 80% success rate that it will work. Sometimes it doesn't, some games still don't work regardless. Planning to just get a new PS5 this year.
Add a comment
Add your answer
Owen Reslie will be eternally grateful.
Past 24 Hours: 11
Past 7 Days: 57
Past 30 Days: 334
All Time: 17,723
