Revamped version of the iPhone 3G with faster processing speeds. Repair of this device is similar to the 3G, and requires simple screwdrivers and prying tools. Model A1303 / 16 or 32 GB capacity / black or white plastic back.
1958 Questions View all
weak wifi signal after replacing battery,but everything else works
I have a weak wifi signal after replacing battery, but everything else works on it, how do I restore wifi to normal range, if I'm close to wifi source i have it but the further away the weaker signal becomes, I've never had this problem b'fore any suggestions on what or how to look for?
Update
Thanks Brad for the advice!!
Rudy
Add a comment
1 Answer
Chosen Solution
The Flex Connector #6 is loose from the Logic Board. It is a very small snap top connector. Look at it closely from the sides to make sure you are exactly over its correct spot and push it back down very carefully to the Logic Board. Before opening and during all repairs on the iPhone 3GS make sure the iPhone is OFF.
Score 2
Add a comment
Add your answer
dwindmill will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 702
