Revamped version of the iPhone 3G with faster processing speeds. Repair of this device is similar to the 3G, and requires simple screwdrivers and prying tools. Model A1303 / 8, 16 or 32 GB capacity / black or white plastic back.
1500 Questions View all
How to stop my iPhone from constantly restarting?
So basically if I shut off my iPhone 3GS 32g manually within seconds it will be turning itself back on again AND proceed to be on for about 2 minutes THEN shut itself off again. This continues repeatedly until I quickly go to settings and reset the iPhone (losing all my personal setting, not my contacts and apps.). This is INCREDIBLY ANNOYING. Also, I have never had battery issues and my battery life lasts a long time so I don't believe that is the issue. I have researched this question but most everyone says something similar but Ive never found the same problem and most of the answers for those are the battery.
Its 3 years old. It's never been wet or dropped hard. I'm running 5.0.1 .
I have run out of idea...
PLEASE HELP!
Score -1
2 Comments
Can you give us a little info on your phone? How old is it? Which iOS are you running? Any water damage or hard drops?
by
Have you tried going back to iOS 4? iOS 5 is supposed to work with the 3GS but it wasn't exactly designed for use with it. That's unfortunately the only idea I have if there hasnt been any other abuse.
by
Add a comment
Chosen Solution
Reformat your phone and don't choose to restore from backup. It could be some rogue settings that are causing it to do this. Use it for a bit as if you had just got it with only factory settings and if it doesn't give you any problems then it should be clear that it is something with your data.
Add a comment
My iphone 3gs 32g is restarting itself there i see just the logo apple and it again turn off and restart i can't go to settings to restore what should i do please give me an answer
Add a comment
Add your answer
Eddie will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 5,027
