Released January 2020, identified by model numbers SM-A015F, SM-A015F/DS, SM-A015G, SM-A015G/DS, SM-A015M, SM-A015M/DS, SM-A015T1, SM-S111DL, SM-A015V, SM-A015A
I forgot my lock screen pin.
I forgot my lock screen pin. how can I get into my phone?
Score 23
2 Comments
Do not open pin
by
Inggris
[code]forgot to lock the screen[/code]
by
Add a comment
Most Helpful Answer
Hi @jenaspage2
If the remote unlock option has been enabled on the phone then the screen lock could always be unlocked remotely via the user's Samsung Account or Google account remote unlock feature. This is if there is a Samsung account or a Google account associated with the phone of course..
If you can't remember the user ID and password for the account then a hard reset will lock you out as well due to the FRP lock being enabled by the reset. You will then have to bypass it to access the phone but your data will have been erased by the reset and will be lost, unless you have done a recent a backup
Score 4
1 Comment:
How do I perform the frp bypass for my a01
by
Add a comment
HardReset.info:
How to hard reset SAMSUNG Galaxy A01
  1. Begin by pushing Volume Down + Power button for a couple of seconds.
  2. If the screen goes dark start holding Volume Up and Power keys for a short while.
  3. Release all keys when the SAMSUNG Galaxy logo shows up.
  4. Then select Wipe data/factory reset by using Volume keys to navigate and the Power button to confirm that.
  5. After that choose Factory data reset from the menu and click the Power key once.
  6. At last, select Reboot system now with the Power button.
  7. Good job! All your data was removed during the whole operation.
Score 1
Add a comment
The only option is unfortunately to do a hard reset of the device.
Good luck!
Add a comment
Forgetting your lock screen PIN can be stressful, but don't panic. First, try to remember any possible combinations. If that fails, check if you have enabled the "Forgot PIN" option, which may prompt you to use your Google account or a backup PIN to unlock your device.
Another option is to use Android Device Manager or Find My Device (for Android) or iCloud (for iOS) to remotely lock or erase your device. As a last resort, consider factory resetting your device, which will erase all data but allow you to regain access. Always keep a backup of important data to prevent loss.
Add a comment
Factory reset
Add a comment
Add your answer
Angela Lockhart will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 15
Past 30 Days: 71
All Time: 3,811
