The PlayStation 3 (or commonly known as the PS3) is the third home computer entertainment system produced by Sony Computer Entertainment, and the successor to the PlayStation 2. It was released November 11, 2006
656 Questions View all
Able to use a 220volt PS3 here with 110volt?
I have a PS3 given to me while in France that is set up for 220 volts and want to play it here in the US. Is this possible? How do I make it able to run off of 110volts?
Do I need to switch out the power supply with a different one or is there an adapter that would work?
Add a comment
Chosen Solution
tim, you will not need to purchase anything but the power cable from the PS3 to the outlet. This only due to the different design of the outlets. The PS3 has a a dual voltage PSU 110/220. You do not require a transformer or any other device. You definitely will not need a transformer. Get the power cord from places like this. Plug and Play....:-) Good Luck
Score 3
Add a comment
To work it on 110v AC source, you need to buy a step up transformer No need to replaced anything.
Mjvillanueva, why would you need this? The PS3 use a dual voltage PSU. Check on here and bookmark this page for later reference.
Add a comment
Add your answer
tim will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 2
All Time: 752
