The Xiaomi Redmi Note 8 is a mid-range smartphone by Xiaomi released October 2019. It has a 6.3" IPS LCD display, a 48 MP main camera, a rear-mounted fingerprint sensor, a 4000 mAh battery, and runs on a Snapdragon 665.
Why does my phone doesn't show any signal from my sim card?
I've added a sim card to my phone(Redmi note 8) but it doesn't show any signal it only shows that the sim card is inserted. I've tried to call someone and it shows me to "Turn off airplane mode to make an call" although my airplane mode isn't on.
Score 3
2 Comments
Is this phone unlocked to use on any cellular network? Sim card faulty? Can you try another sim card?
by
@notbroken The phone is unlocked but i still cant activate the cellular network.Even if i use another sim card it shows that a SIM card is in the phone but it has no signal.
by
Add a comment
1 Answer
Chosen Solution
There are several possible reasons why your phone might not be showing a signal even though you've inserted a SIM card. Some possible reasons include:
  1. The SIM card is not properly inserted into the phone. Make sure that the SIM card is properly seated in the SIM card tray and that the tray is securely closed.
  2. The SIM card is not activated. In some cases, you may need to activate your SIM card before it can be used. Contact your mobile service provider to ask about activating your SIM card.
  3. Your phone is not compatible with the SIM card. Not all SIM cards are compatible with all phones. If you've recently switched to a new phone or a new mobile service provider, make sure that the SIM card you're using is compatible with your phone.
  4. There is an issue with your phone's software. In some cases, a software glitch can cause your phone to not recognize the SIM card. Try restarting your phone and see if that fixes the issue.
Score 2
1 Comment:
none of these fixed my issue...I even flashed my phone
by
Add a comment
Add your answer
Lucarcio will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 7
Past 30 Days: 36
All Time: 7,199
