Repair information and guides for the iPhone 8 that was released on September 22, 2017. Model: A1863, A1905
872 Questions View all
How to remove a iPhone 6s sized pentalobe case from an iPhone 8 case?
So I lost my iPhone 8 case screws and I thought a 6s screw would work from one of my broken phones so it went in but now it won't come out. So the threads of the screw have passed the threads inside the phone and now when I screw it there is no resistance so it can't come out.
Add a comment
Chosen Solution
Insert an opening tool between the screen and chassis above the screw and apply gentle pressure like you were trying to open the phone. With pressure applied unscrew the screw, hopefully it will come out. Done it loads of times with threaded screens.
Score 2
Add a comment
Hey, LogicalBot
I'm not an expert on phones, and I might not fully understand this myself, but I've got a few tips for stuck screws. There are a few things you can try to get it out.
  • Use the exact size screwdriver.
  • Spray lubricant to loosen it
  • Try the rubber band trick.
  • If none of these work, you have a more serious option that I've used for larger screws. I'm not sure if or how it will work on an iPhone.
  • The Glue and Nut method
As I said before, I'm not an iPhone expert, so some of this might not work. I'm sorry if it doesn't, but I hope it's helpful.
1 Comment:
I tried to use the exact pentalobe screwdriver but the screw is so far past the thread on the screen my screwdriver can't grip it strong enough to pull it out and back onto the threads.
by
Add a comment
Add your answer
LogicalBot will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 35
