4-inch iPhone released in March 2016 with similar hardware specifications to the 6S. Available in Silver, Space Grey, Gold, or Rose Gold with 16/32/64/128 GB storage options. Model: A1662 and A1723
Audio, headphone jack, and home button not working
I recently replaced the battery in the phone and when I finished I noticed the home button, audio and headphone jack all don’t work. I’ve gone back multiple times to see if there is any visible damage or disconnected cables but nothing seems out of place. Im wondering if this is a problem with the logic board.
Add a comment
Chosen Solution
Wow, seems like you've got a lot going on there. I'm frankly puzzled regarding these seemingly unrelated failures all occurring together. The thing is, the home button could be explainable by having stressed the flex cable when you were opening it up; to be honest that connector is a crappy design that just begs to be damaged when you're down there trying to fiddle with that stupid clip holding the connection. If that's what happened, it's easy enough to fix by replacing the home button, but unfortunately that's at the expense of your Touch ID function since only Apple can restore that.
With regard to the audio and headphone functions, that one's a mystery. Assuming you followed the iFixit Battery Replacement guide, there's no need to fuss with any of the parts down there at the bottom of the phone. The two only have a couple of things in common; one, they're both audio signals generated on the logic board, and two, they're both connected to the motherboard through the lighting cable assembly. I'm assuming when you say that audio doesn't work that you're referring to the lower speaker; is that right?
Did you have trouble getting the battery out, by any chance? As in, the stretchy adhesive tabs broke and you had to work the batteries away from the adhesive to remove it? The only thing I can think of if that's the case is that maybe you dislodged the lighting cable connector since it's right next to the battery. Is that one of the things you checked when you went back in and looked it over? If not, it would be worth opening it up and unplugging and resecuring that flex cable on the motherboard. Of course, the taptic engine and the lightning port are also on that cable, so you might think those would be affected as well, but it just depends how the connector is sitting in the socket as to what might work and what doesn't.
But yeah, motherboards generally don't just lose functions at random as a result of changing the battery, so that would really be last on my list of suspects.
Have you tried doing an update on the phone to see if a restore makes any difference? You can try the "Reset All Settings" thing too; it's always worth trying the software solutions first before throwing hardware at it.
So my suggestion would be to check over the home button flex carefully with a magnifying glass and a bright light. Take a look at the both sides of the connector and see if you can find any bent, broken or missing pins, then check that lightning connector and let us know what you find. After that we can try and figure out where to go next to get your phone back to normal.
Score 2
2 Comments:
During removal of the battery I did accidentally bump the lightning cable out of the socket, I feared I might of broken something then.
I went back and checked the cables again and turns out both weren’t in the socket completely. Thankfully neither the lightning cable or the home button were damaged. Got in such a panic over such a simple mistake lol.
by
@lts672 So it's all working now? Awesome! It always helps to have a second set of eyes on something when you're stuck. Glad we could help, and congratulations on a successful repair! Woot!
by
Add a comment
I might wonder if damage was done to the dock cable assembly (or lightning port assembly).
Totally agree that the home button on these is a lousy design. But the common thing on these issues is that they are all part of the dock cable assembly. Could also be just the cable connection to the board is loose. But if that doesn't resolve it, I would make sure that cable didn't get nicked or damaged during the repair.
iPhone SE and 5S batteries are a bit of a drag because of the limited clearance between it and other parts. And they can be tricky to get out at times.
This lightning connector assembly includes the lightning connector, primary microphone, and headphone jack and is compatible with 1st generation iPhone SE models. Image
Product
iPhone SE (1st Gen) Lightning Connector and Headphone Jack
$19.99
Score 2
1 Comment:
Alisha, you are absolutely right; I forgot all about the fact that the connector for the home button goes right there to the lighting flex. Yeah, it's sounding more and more like a common lighting port assembly issue. Thanks, I owe you a beer (or beverage of your choice :).
by
Add a comment
Add your answer
LtS67 will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 7
All Time: 148
