Revamped version of the iPhone 3G with faster processing speeds. Repair of this device is similar to the 3G, and requires simple screwdrivers and prying tools. Model A1303 / 8, 16 or 32 GB capacity / black or white plastic back.
1500 Questions View all
Repairing water damaged iPhone - backlight intermittent
I am repairing a 3gs that had water damage. I took it apart down and gave the logic board a good soak in 90% alcohol, and gently scrubbed it down with a toothbrush (noticing and removing some corrosion that appeared on the 6r8 coil). Backlight worked for 3 days. This could help most people.
I, however, am not most people. The backlight went out again. Soaked the logic board again in alcohol, overnight this time. Worked until I shut the phone off, then no backlight when I turned it on again. Any ideas on this one?
Score 1
1 Comment
test the 6r8 is working with a multimeter etc,I'd take a good look at connector 1.. sometimes the coil is fine and it's the pin/pathway that corrodes.
by
Add a comment
1 Answer
Chosen Solution
If you are certain you have a working LCD and that you cleaned the iPhone properly using this as your guide.. It was written for a 3G but does apply to your phone as well. If all that works out, I would go ahead and replace the coil. As you stated in your question " (noticing and removing some corrosion that appeared on the 6r8 coil)", there may be more damage on your coil. Hope this helps, good luck.
Score 2
Add a comment
Add your answer
Garrett will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 973
