CDMA version of the fourth generation iPhone. Repair is straightforward, but the front glass and LCD must be replaced as a unit. 16 or 32 GB / Model A1349 / CDMA compatibility.
418 Questions View all
How easy is a color switch from white to red?
I want to switch my white iPhone 4 to a red or maybe black i have seen videos and things but those are professionals how easy is it for a ordinary guy to do this. Also what are the dangers and do you have any tips?
Add a comment
1 Answer
Chosen Solution
It isn't too bad, the only real 'issue' is that in order to change the front you [near enough] have to take everything out and put it back in again, you'd only really need to follow this guide:
iPhone 4 Verizon Display Assembly Replacement
as for tips:
when putting the new display assembly on make sure the digitiser and screen connectors don't get caught/pinched between the assembly and the mid casing, just give them a gentle pull to help them through when you're putting the assembly on.
be patient :)
Score 1
Thank you and is there any problem with static electricity shocking the components of the iPhone??
always best to be careful but in a pinch, probably not.
Add a comment
Add your answer
kaine will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 532
