Model A1136 / 30, 60, or 80 GB hard drive / black or white plastic front
813 Questions View all
iPod 5th gen with iPod Classic motherboard?
are 5th gen components compatible with a classic mother board? Because my 5th gen mb was damaged and I want to replace it with a classic mother board.
Thanks
Comments:
some are and some are not, depends on which components you are referring to. The HDD for example is...but you will need a different cable.
by
@oldturkey03
Thanks for responding!
Ok it seems the touch wheel works but the main component in question is the video display will that work? Also I assume the hold switch will work so the hdd will require a different cable? i have a zif ssd that I am using do you still think i will need a different cable?
thanks
by
The display is different and slightly offset, this will cause your connection to not be properly seated.
by
Add a comment
New Battery = Faster iPhone
Fix Kits starting at $16.99
1 Answer
Chosen Solution
The display will not work. The ribbon cable is slightly offset and the display is slightly different due to the housing being different. As for your drive, it should work.
Score 1
Add a comment
Add your answer
ciscx85 will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 1,072
