MacBook Pro models with 13" displays
5166 Questions View all
Where can I download AirPort card?
I never had problem with my pro, but i took it to the shop to clean it inside. When i got it back, i couldnt go on the wifi. i never had a problem with it. Never skipped or dropped me off for no reason. I am thinking they might deleted from my computer by accident. I dont know what to do or where i need to find any help. Maybe they moved something around inside and that is why it doesnt work. Should i get the cover off? If yes, where can i find the modem that is controlled by that? Please help... Thanks..
Score 1
Add a comment
1 Answer
Chosen Solution
First go under he Apple (upper left hand corner) to about this Mac. Then hit more info. Go to Network > Airport and see if your machine sees the Airport card. If so, Go under the Apple to System Preferences > Internet & Wireless > Network. Click on the Airport button and then the Assist Me and follow directions.
Score 5
I did what you told me and finally i found the Airport in the System Preferences>Internet>Network. When i try to click on Assist me. it cant click on the option "I use AirPort to connect to the Internet wirelessly." What is my next step i have to do?
Sounds like your card may have gone bad or the software corrupted. Try reinstalling the airport software, then down load the updates and try it again. This failing, give us the last three figures of your serial number so we can get you to the correct guides and check your cable connections then possibly replace your airport card.
Yes i wanted to reinstall the software, but i dont know where i can find it. Where should I look for it?
Do a custom install from your system installation disk. Then download and install all updates.
My cd player is not working. Other option??
Add a comment
Add your answer
Rita Liliom will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 12
All Time: 1,373
