In August 2000, the ninth-generation Corolla was introduced in Japan, with edgier styling and more technology to bring the nameplate into the 21st century.
38 Questions View all
What tools are required to replace the serpentine belt?
Toyota Corolla 2008
Comments:
The 19mm nut to relieve the tension is just above the tension wheel. Very hard to see. I went to an auto parts store and asked to look at the tension bracket to see where it was located. Helped a lot.
by
Add a comment
New Battery = Faster iPhone
Fix Kits starting at $16.99
Chosen Solution
You will need a breaker bar with a 19mm socket. Turn the drive belt tensioner clockwise (toward the radiator) to relieve tension on the belt, and then remove the belt. Then return the tensioner to the unloaded position.
Score 3
Add a comment
easy way to replace serpentine belt on a 1999 dodge caravan 3.8 engine
Add a comment
Add your answer
Rob will be eternally grateful.
Past 24 Hours: 8
Past 7 Days: 21
Past 30 Days: 69
All Time: 3,360
