My iPhone mic does not work with call application.
Hello,
I have an iPhone 4 and when callin the oposit side cannot hear me. Although the mic does in the memo application.
Thanks to questions awnsers here I did the following:
First I replaced the mic right under the dock.
After that I tried isolating the 2nd (upper) mic.
Also with tightening/loosening the "special screw" where, a screw, screws in to.
Then I tried replacing the 2nd mic. Still not functioning.
Now I thought reballing the audio chip would be the only and last option. But when I opened up the metal casing from the mother board I saw something strange.
When you have the motherboard laying down like an "L" then you see the audio chip in the down left corner. And just right from this audio chip is a smaller chip. I wandered if this has anything to do with my audio chip couse this chip looks a little damaged?
Would be nice if anyone knows what it is/does.
So I won't be spending a lot of money on reballing the audio chip if that is not the problem.
Thanks
I Thought it would be the audio ic on THE motherbord.
But when i opened the metal casing, where the audio ic is located, i see there is another small chip/ic or something that did not look like it should be. It needs to be in the form of a square but it looks if one side is broken of a bit.
It looks that there is some copperwire inside...
If Anyone knows what this does, than i can consider replacing that or reball the audio ic.
Thanks
by vincent
