A handheld gaming console made by Valve, released on February 25, 2022.
108 Questions View all
Will the included Steam Deck AC (US) adapter work in INDIA?
I have purchased a steam deck from the US, its in transit to India. I was wondering if the included Adapter will work here. The voltage output rated from the power socket in India is 230V @ 50hz and the technical specs of the included charger does mention 100-240VAC 1.2A 50-60Hz as Power Input. I just want to be sure and not cause damage to anything or harm myself If I'm in the wrong.
Add a comment
1 Answer
Chosen Solution
Hi,
As you said the specifications for the power supply in India are 230VAC @50Hz.
The power adapter is fine the only problem may be that you may need to use an adapter (example only) to make it suitable to plug into the wall outlet as it no doubt has a plug arrangement for a US wall outlet,
Score 2
1 Comment:
Hello jayeff,
Thank you for the Quick response and resolution. I do already have one of those adapters on hand. Cheers!
by
Add a comment
Add your answer
Aman Dhir will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 16
Past 30 Days: 65
All Time: 431
