Second generation of iPhone. Model A1241 / 8 or 16 GB capacity / black or white plastic back. Repair is more straightforward than the first iPhone. requires screwdrivers, prying, and suction tools.
1496 Questions View all
Black Conductive Pad under battery inside rear panel?
Where can you get these one side adhesive conductive copper / aluminium pads or tapes, do you know where ?
Comments:
Is this a necessary component?
by
I think so, because when the battery charges, it heats up. The pad takes the heat and via the body transfers it out of the case.....
by
do you mean on back of motherboard or on inside of rear case???
by
Inside of rear case behind battery....
by
Slide 30 in changing the rear case gives a good view.
by
Show 2 more comments
Add a comment
New Battery = Faster iPhone
Fix Kits starting at $16.99
Chosen Solution
The copper helps dissipate heat, like a heatsink. When I work on iPod's, for example the touch 4g, I also add a dab of arctic silver paste since the paste is usually dried up.
You can find adhesive backed copper sheets, just cut to fit, google :
copper foil sheet
Add a comment
Thanks
Add a comment
Add your answer
avdk will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 202
