Wi-Fi only version of Apple's 2nd generation iPad Air. Model A1566.
211 Questions View all
My Wifi is Greyed out, How could I fix it?
I have tried a reset and done everything WiFi works over Bluetooth using my iPhone but is very slow, It used to work just fine but now it doesnt it is a 16GB iPad Air 2.
Score 2
1 Comment
Why hello Xavier. Trying to fix your iPad lol The wifi antenna might be bad.
by
Add a comment
Most Helpful Answer
This will not be an antenna issue. If the Wi-Fi is greyed out you defiantly have a board issue. You will need to check that the Wi-Fi chip is getting power, if it is you will need to re-ball or replace the chip. If it isn’t getting power you will need to find the faulty component that has failed. Microsoldering will be needed to fix this problem.
Score 4
1 Comment:
UPDATE: I just plugged it in and powered it on for the first time in a month, Wifi is back so I think it keeps getting overvolted or something like that.
by
Add a comment
It sounds like it could be an issue with the Wi-Fi Antenna. If you follow this guide to check the state of the antenna. I would attempt to reseat the antenna before attempting a replacement. Otherwise, it sounds like it could be an issue with the logic board.
Score 2
1 Comment:
by
Add a comment
Add your answer
Xavier K will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 12
Past 30 Days: 43
All Time: 859
