Shop the Holiday Gift Guide
Need help finding replacement fan for HP Spectre x360 15
TL;DR at the bottom
So I have an HP Spectre 15 Convertible (15-df1033dx) that I bought in Jan 2020 but I'm pretty sure it is from a late 2019 run.
The left fan (the one for the GPU) has been rattling for the past year and is now just quiet. Also, the battery life has been falling (probably due to my poor habits of keeping it plugged in and charging at 100%), and the touchpad (which is on top of the battery) has been bulging up slightly so I'm pretty sure it should be replaced.
I've tracked down the part numbers for the left fan (L38107-001) and the battery (L29184-005). I found an eBay listing for the battery that seems pretty good, but I can't seem to find a good source for the fan. I've found something on a site called notebookparts.com but it doesn't exactly look reliable.
TL;DR
I need an HP L38107-001 fan part, can't seem to find a good/safe source, help pls?
Add a comment
1 Answer
Chosen Solution
Hi @jafg147,
Did you try just searching for the fan's part number?
Once you have found suppliers that may suit, go online and check if there are any "reviews" regarding the supplier. Check if the supplier has a good returns policy and what sort of warranty or guarantee they provide. Once you have narrowed down your choices to 2 or 3 go with the one that you feel that you would be most comfortable dealing with.
Recommendations are discouraged on ifixit as they may be just spam and also may not be helpful to you as this is a worldwide forum and the location of a supplier may not be suitable as your location is unknown. Do your own research and trust your instincts.
Here's the maintenance and service manual, taken from the support webpage for your model, that may help with the fan and battery replacement.
If you click on the product number of your laptop, you will find the part numbers for all the replaceable parts that are used in your laptop. The product number is on the info label on the bottom of the laptop.
It verifies that the left fan's HP part number for your model is L38107-001 as there are two left fans available for the model series:
The left fan for use only on computer models equipped with an Intel Core i7-8750H processor (L38109-001) and the left fan for use only on computer models equipped with an Intel Core i7-8565U processor (L38107-001)
Hopefully this is of some help.
Score 1
Add a comment
Add your answer
jafg147 will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 24
All Time: 1,134
