Fourth generation iPhone. Repair is straightforward, but the front glass and LCD must be replaced as a unit. GSM / 8, 16, or 32 GB capacity / Model A1332 / Black and White. This page aims to help users troubleshoot, fix, and seek help for the iPhone 4.
2375 Questions View all
Replaced water damaged iPhone 4 battery. Worked, died, now nothing!
My iphone 4 got flushed down the toilet, and i (very stupidly) used it when it came out. It then died, So i took off the back, and put both pieces in a bag of rice, which i swapped for silica gel a week later. This was around 2-3 months ago.
When i tried to turn it on, it was in a continuous boot loop. So i purchased a new battery which i fitted today. The phone turned on, was working fine, but the battery was only 36% when it came on, then it drained super fast. It then died, and hasn't worked since!
Can anyone help?
Add a comment
1 Answer
Chosen Solution
Emma, " I would definitely proceed with this guide even so it is for a 3G, it is still valid for your phone as well. The cleaning should eliminate any corrosion which may plaque your. Once its clean, you can reevaluate and see what happens. " Make sure you clean the dock connector as well, check for bend, broken and corroded pins as well.Hope this helps, good luck.
Score 2
Add a comment
Add your answer
Emma will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 1,240
