Grey Screen Boot, Open Firmware
Hello,
A few years ago my powerbook g4's logic board fried and I kept it in a drawer until a few days ago when I bought a used 1.5Ghz Logic Board and replaced it. Now the computer will boot but I only get a grey screen. I've searched a lot around and the best I could find was this: http://hintsforums.macworld.com/showthre...
that guy has my same problem. It seem though that everything is working fine but I'm not getting anything on the display (except for grey). I can get into Open-Firmware but I'm typing blindly. Does anyone know why this happens and how to fix it?
I have tried
- Reset PRAM, NVRAM
- Won't seem to boot off a CD (with c held down)
Score -1
Add a comment
Chosen Solution
Verify that the Airport Extreme card is firmly seated. I've seen cases on the 12" PowerBook where if it's just slightly out of its socket, the machine will go into open firmware, or otherwise act strange.
Beyond that, is it a faint, sort of opaque grey screen, or a solid white screen? The odd-colored grey screen can be an indication that the inverter light is working, but the video signal is not coming across, in which case I'd make sure the video cable is firmly seated on the logic board side. I'd try booting in option mode, i.e. power on with the option key held down, and if you DON'T see the option menu, that generally means you have a video-related issue. You can also try the external monitor as Mayer suggests.
Score 2
Add a comment
Most Helpful Answer
First try connecting to an external monitor to see if you have video issues.
Score 3
1 Comment:
I did. It didn't work...
by
Add a comment
Add your answer
joablen will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 1,093
