To replace the front bezel, must the entire screen be disassembled?
I have a MacBook Pro, 15 in, with the fatigue cracks. The screen works fine for now, but I want to fix it before something else happens. The instruction place the repair as very difficult, is it really going to be that hard? I've done a hard drive swap that was pretty easy. I'd like to keep the computer going for a while longer. It's just an internet device for my wife.
Update
MacBook Pro
Model Identifier: MacBookPro3,1
Processor Name: Intel Core 2 Duo
Processor Speed: 2.2 GHz
Number Of Processors: 1
Total Number Of Cores: 2
L2 Cache: 4 MB
Memory: 2 GB
Bus Speed: 800 MHz
Boot ROM Version: MBP31.0070.B07
SMC Version (system): 1.16f11
Serial Number (system): xxxxxxxxXAH
Hardware UUID: deleted
Thx
Comments:
there are EIGHT DEVICES - which is yours?
by
Please give us the last 3 characters of your serial number so we can determine your exact machine and be in a better position to advise you.
by
Add a comment
New Battery = Faster iPhone
Fix Kits starting at $16.99
1 Answer
Chosen Solution
I believe THIS GUIDE is what you refer to. The HDD replacement gets you a bout 1/3 way thru what you need to do to replace the Bezel. I'd say that if you are capable of doing the HDD then you are capable of doing the bezel. It will only require that you read the guide carefully and follow each step, take your time especially with the reassembly - check/double-check all cable etc are seated before you move on. Nothing that you haven't done before :)
Score 1
Add a comment
Add your answer
dbkay50 will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 1,076
