Revamped version of the iPhone 3G with faster processing speeds. Repair of this device is similar to the 3G, and requires simple screwdrivers and prying tools. Model A1303 / 16 or 32 GB capacity / black or white plastic back.
1956 Questions View all
How Can I upgrade iPhones RAM?
i am wondering if anyone can tell me if it is possible to take my 64gb Memory from out of my non working iphone and put it in my new 8gb?
Comments:
jay, if the answer you received has helped you resolve your issues, all you have left to do is to accept it. That way anybody looking on here for an answer to a similar question will see what works. Good Luck and welcome to ifixit
by
FWIW - I think he should have accepted pollytintops answer
by
So do I, especially since the answer by nah is inaccurate.....but its his choice.
by
Add a comment
1 Answer
Chosen Solution
You can transpose the motherboards but you can't remove memory separately.
Score 2
Comments:
ok thanks guys
by
wrong there are small little chips that you can do but its really risky and you need a heat gun and solder gun . i done it before i it worked . make sure you have the same model
by
you may consider others answer as wrong, but you are giving a wrong answer yourself. jay is talking about possibly replacing the memory of an 8gb logic board with the IC from an 64gb, and that is not possible. Your firmware may not know what to do with those chips. There are plenty of people on here that do board level repair, and replace even the smallest SMD components, but in general it is not a DIY repair. I concur with my colleague pollytintop, it is not possible for the average DIY'er to replace those. Replace the whole logic board.
by
Add a comment
Add your answer
jay will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 8
Past 30 Days: 18
All Time: 3,489
