Released October 2008 / 2.4, 2.53, 2.66, 2.8 or 2.93 GHz Core 2 Duo Processor
376 Questions View all
Question Closed
Is the black plastic bar on the back of the unibody replacable?
My MacBook Pro fell down one time, and the black long bar on the back of the unibody (the one who probably hides the display's hinges?) is broken.
I could not find this part in the iFixit parts list for my MacBook Pro model, so I wonder if it is included in another part, but couldn't find out so far.
To find the part which I mean: Close the MacBook Pro, and lay it lid up on a table. If you then turn the MacBook Pro so that the Apple logo is the right way for you to see, bring your eye level to the table, so that you are looking at the MacBook Pro's backside (NOT the underside of the body). There is a long black bar, which probably hides the display hinges. This plastic bar I mean.
Is it available seperately? And if not, which part is it available with?
Score 1
Add a comment
Chosen Solution
Do you mean this part? It appears to cover the hing assembly
Score 3
2 Comments:
Yes exactly, that's the one. Is it available seperately?
by
A quick Google found THIS and THIS so I assume it is readily available
by
Add a comment
Try powerbookmedic.com, they've got that and practically everything else. Gdluck!
Add a comment
quick ebay search http://www.ebay.com/itm/MacBook-Pro-15-U...
pretty cheap. but you need to remove the display panel to replace it. You will need to slide it to the right and pull it out. Reverse to put it back.
1 Comment:
Thanks for this comment! I couldn't for the life of me figure how to get it off the display assembly.
by
Add a comment
Hi there!
I have the same problem, too.
Is it really necessary to replace it or can I bear to keep it broken?
Many thanks to your replies.
Ale
Add a comment
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 26,535
