dropped in pool water damage
dropped in pool
You should also look at this guide water damaged electronics
and THIS Teardown
Was it a salt water pool? If so the salt will cause corrosion very fast so time is of the essence.
I used to repair 2-way radios that were dropped into sewers by repair crews... The standard procedure was tell them to take out batteries and put in a bucket of clean water and bring to us ASAP. We would then disassemble, wash with distilled water, alcohol, and dry in an oven at around 45C. Usually did the trick
If possible get it open and battery removed and wash it down with alcohol and dry it. leaving the battery connected will likely mean additional damage as corrosion/salt causes shorts on the electronic components, boards etc.
Some report success putting device in a jar of rice to absorb the water but this doesn't address corrosion issues now or in the future.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 221
