A compilation of guides for counter-top and handheld blender repair.
183 Questions View all
Why have blades in carafe stopped turning easily?
I have a K-TEC Champ HP3 blender. Counter shows I've used it 187 times. For some reason the blades in the carafe have become stiff and won't turn easily causing the motor to sound very high-pitched when I try to use it. It worked fine the last time I used it which was less than a month ago. Tried 3-in-1 oil and doesn't help. Any suggestions would be greatly appreciated!
Thanks!
Add a comment
Free shipping on all orders over $100 or containing a Pro Tech Toolkit!
Browse Our Store
Ever fixed something? That’s Genius.
Share your repair story with #ImAGenius
We Are All Geniuses
1 Answer
Chosen Solution
Sounds like the bearing has seized up. Oiling it may work but you risk contaminating your food! They are usually a sealed bearing packed with a food grade lubricant.
Washing the carafe in a dishwasher can exacerbate these types of failures due to the high temperatures and chemicals
You may need to replace the entire carafe if you cant get a new blade/bearing assy.
THIS MANUAL appears to be the same/similar device with a different name - Blendtec are a division of K-TEC. Section 7.3 says to contact customer support. Perhaps it is repairable??
Score 2
Add a comment
Add your answer
Carol will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 8
All Time: 1,943
