Why does my heater only blow cold air?
My air conditioning seems to be working apart for the fact that I don't have any warm air. Ihave checked all the relevant fuses and they seem ok.
Cancel
Rep: 1
Jim,
First check to see you have a coolant mixture in the radiator. Do this by allowing the car engine to cool, removing the radiator cap and filling with a water/coolant mixture. If there is not enough coolant to circulate in the system, it will not fill the heater core and you will only get cold air.
Start there and check back with us.
Frank
Past 24 Hours: 0
Past 7 Days: 9
Past 30 Days: 29
All Time: 3,714
We have a chance to guarantee our right to repair electronic equipment—like smartphones, computers, and even farm equipment. This is a once-in-a-generation chance to protect local repair jobs—the corner mom-and-pop repair shops that keep getting squeezed out by manufacturers.
Join the cause and tell your state representative to support Right to Repair. Tell them you believe repair should be fair, affordable, and accessible. Stand up for your right to repair!
Are we talking about a car AC or home AC?In a car this can be due to malfunctioning of Thermostat.
In a home AC it depends on the type of AC itself and the heat generating mechanism.
It will help me to help you further and better if you supply the model number of your AC.
by Vahid
