The HP Elitebook x360 1030 G3 is a 13.3" two-in-one laptop released in 2018. This model name can be found on the underside of the laptop in "Project Name."
The charging port is wobbly what part should I purchase to replace it?
The charging port on my hp elitebook 360x 1030 is wobbly and only works if I lean it on the side and wiggle and angle the cable end just so. What should I purchase in order to fix it? Everything else seems fine, l'm not too concerned about battery life.
Score 1
Add a comment
1 Answer
Chosen Solution
@mandymoomin this one uses a USB Type-C power connector which is soldered to the motherboard. You'd be looking for a part like this and somebody who can solder this particular part. Not an easy task due to the" hidden pins" There are a couple of good board level repair techs on here but suggestions are only of use if you are in the USA
Score 1
1 Comment:
Ah, thank you so much. I was hoping to be able to do it myself, but that sounds beyond me. I'm not in the US unfortunately.
by
Add a comment
Add your answer
Mandy will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 8
All Time: 309
