S9+cracked front and back but not miss calibrated all ask works but af
S9+ cracked ask the way around but ask works great afraid it will fall apart soon what do I need to do to fix
Hi Elaina,
It seems obvious you'll need to replace both the front and the back glass on the phone, which should be fairly straight-forward assuming your case isn't bent. If it is you'll probably need to replace that as well, unless it can be straightened perfectly; unfortunately there isn't a guide here on iFixit for that, so hopefully replacing the glass is all you need to do.
Ordinarily you would need to follow two different guides to replace both the screen and the back, but for your phone you have to remove the back anyway to get to the LCD, so replacing the back glass is just part of the procedure you'll have to do anyway.
You can shop around for a new screen, but you can buy it right here on iFixit if you want. I'd suggest getting the Fix Kit, as it includes both the front and the rear adhesives you'll need to do the job right.
Galaxy S9 Plus Screen: AMOLED + Digitizer Replacement Kit - iFixit
Of course, you'll need the rear cover as well, which you can also get here.
Galaxy S9+ Rear Glass Panel/Cover - iFixit Store
If you do end up needing the midframe because it's bent, that's available as well.
Galaxy S9+ Midframe Assembly - iFixit Store
For the glass, just follow the guide from beginning to end and use the new parts when you're reassembling it.
Samsung Galaxy S9 Plus Display Replacement - iFixit Repair Guide
If the worst case happens and you have to replace the midframe as well, you can use the screen replacement guide as a start, then use the rest of the guides to take out as many other parts as possible. The teardown should give you a pretty good idea of what order to do things in and anything else not covered by guides.
Samsung Galaxy S9+ Teardown - iFixit
Best of luck with your repair; let us know how it goes!
Product
$16.99
Product
$59.99
Product
$156.99
Guide
Difficulty:
Moderate
Guide
Difficulty:
Difficult
50 minutes - 2 hours
Hi
Sorry to here about your phone ,here what you need to get it line new again:-)
First you need there 2 guides
Here’s one for the screen
And here’s one for the back glass
Samsung Galaxy S9 Plus Rear Glass Removal
You will also need parts
Here’s a link to a screen
And here’s a link for a back glass
https://www.ebay.com/itm/173781604336
And back glass adhesive
https://www.ebay.com/itm/265370524881
When ordering the parts for your ifixit part make sure so select the kit Version as it includes tools and adhesive to finish your repair
Hopefully this helps
Any questions please ask
Guide
Difficulty:
Moderate
10 - 25 minutes
Guide
Difficulty:
Difficult
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 7
All Time: 131
