The Game Boy, released July 31,1989, is characterized by a large grey casing and model number DMG-01.
26 Questions View all
Can I repair problem with power?
Will not turn on with fresh batteries - connections are tight and clean. Power is erratic when adapter is plugged in - the power light comes on and the game plays until just a little jiggle interrupts play then screen goes dark and power light goes out. If I unscrew the back what should I look for?
Add a comment
New Battery = Faster iPhone
Fix Kits starting at $16.99
Chosen Solution
katy, check for loose or corroded contacts on your logic board power connector. Try a good cleaning by following this guide Electronics Water Damage. let us know what you find once you open it up, take lots of pictures....:-)
Score 2
Add a comment
Take a look at these guides. They will assist you in getting into the device.
2 of the battery terminals are soldered directly to the main board so check they are OK and not cracked/loose. Also check the socket where the power adapter plugs in (if it is an option) on the main board - again check the solder joints aren't cracked/loose
HIH
Score 1
Add a comment
Add your answer
katy will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 15
Past 30 Days: 42
All Time: 2,353
