Released in May 2020, the 13" MacBook Pro features quad-core Intel 10th generation Core i5 and i7 processors, and Intel Iris Plus integrated graphics. (Model A2251/EMC3348 with four Thunderbolt 3 ports)
63 Questions View all
What is this opening for?
have a 2020 MBP 13 (A2251) While replacing the touch bar, found the mic hole under it just above the 2 key. The hole is closed up by the touch bar's sticky tape so was curious what this is for?
For keyboard noise cancellation? Tried photobooth video while tapping on the keyboard and can hear it (does the same on my Macbook Pro M1 with the same touch bar+mic design)
Anyway, like to test this mic since I replaced the touch bar but not sure how. I did clean out the hole but not poke down really far to avoid damaging the mic (didn't peel it off to avoid breaking any seals)
Add a comment
1 Answer
Most Helpful Answer
From what I have documented that is the noise cancellation mic
Noise cancellation is a bit tricky!In a quite room with nothing but you hitting the keys there is no cancellation! So yes you will hear them. The main mics need to have something that is present that is at a higher volume for the cancellation to be effective.
Score 1
Add a comment
Add your answer
Howard will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 3
All Time: 32
