How to strip the computer and open the DVD driver
I accidentally put a memory stick in the DVD driver and couldn't get it back, it fell down inside...
Here is a link to a previous post involving the same sort of problem. Hope it helps you resolve your problem. If it fails look up the guide for your computer and remove/disassemble the drive to remove the stick but please try the other methods first to avoid possible difficulties in breaking down your computer. Good luck.
There are many great guides HERE
Without the exact model I cannot be more specific but if you follow the links you should be able to locate a teardown or repair guide for your model. Opening it up should not present much of an issue
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 327
