PS3 Braking with the eject button and powwer button
Hi im just asking if i do a fan test with the eject button and the actual power button can my PS3 get broke ?
To test the fan, turn power OFF, hold the eject button.
While holding the eject button, press and HOLD the power button till the power light is green. When you release the button the system should beep
The fan should run at FULL speed and eject any disc that is inside.
the fan should run for around 15 seconds and then stop.The ps3 should then beep 3x and flash a red light.
Power OFF and then power up normally to reset to normal mode after fan test.
THIS WILL NOT BREAK your PS3
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 340
