Model A1174 with 2 GHz Core Duo or Model A1207 with 2.16 or 2.33 GHz Core 2 Duo
212 Questions View all
Where are the Diagnostic LED's on a EMC2105 iMac?
I have a iMac emc 2105 20" model that will not power on. I have removed the case cover and am trying to locate the diagnostic LED's . There does not appear to be any LED's just to the right of the ram slots visible.
Where are the Diagnostic LED's and what do I have to remove to locate and see them ? I have found numerous references to other models and the diagnostic LED's but not this model.
I have found what might be a LEd on the "bottom" of the unit to the right of the RAM slot, but this is what might be a single LED, certainly not a row of 4 of them are present.
My real problem is that the machine will not power on and I am trying to diagnose whether it is the power supply or the motherboard.
Does this model have a SMC reset button ? If so, where?
Does this model have a internal power on button. If so, where ?
I was hoping to reset the SMC before I went any further -- how do I do that.
There is NOTHING glowing anywhere that I can find. I have not removed the back cover, only the front bezel and screen. I have replaced the backup battery ( Cr2032 on the motherboard). I have tried cmd+option+shift + pwr button reset -- -to no avail.
A pointer to a previous thread that answers this question and provides diagnostics for THIS model would be helpful.
Add a comment
1 Answer
Chosen Solution
You're looking in the right place. They may be covered up by a small piece of black tape that comes up from the bottom edge of the logic board. See if you can locate the tape and remove it.
Score 3
Add a comment
Add your answer
Paul Lodrige will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 1
All Time: 1,390
