The screen goes black while the system is still on
Hi, I have a problem with my MacBook. It’s a 2013 MacBook Pro retina.
Whenever it gets hot a little, the screen goes black while the system is still on. I don’t really understand what could be causing this. I’ve changed the thermal paste but the problem still persists.
Score
0
Lets get some deeper info, install this great app TG Pro It will allow you to see your systems thermals at a deeper level. Take a snap shot of the main window, making sure to capture all of the sensors as some will be below the default window size or take two snapshots and post them here after your system has winked out again Adding images to an existing question That way we can see what is needed.
You should also check your battery as the systems age tells me its time for a replacement, install this gem of an app! CoconutBattery take a snapshot of the apps main window and post it here for us to see as well.
by Dan
@danj I’m unable to install any app because the screen doesn’t turn on, it’s just the fan alone that runs. I still have a feeling it could be the heat sink because the last time I had the thermal paste replaced, it worked well for few days and then back to black screen but this time I doesn’t come on, only the e fan runs.
by Marvelous Awodeji
@muchfreedom - Ok, you’ll need to use an external display then. If that fails to work you’ve have a deeper issue.
by Dan
@danj 😔😔 I don’t have an external display cos I’m in school. I believe if I replace the thermal paste again, I’ll be able to use it for a while.
@muchfreedom - do you have access to a second Mac system?
by Dan
Show 12 more comments
