Repair guides and disassembly information for the 16-inch MacBook Pro released in October of 2021, featuring Apple-designed M1 Pro and M1 Max SoCs. Model A2485.
50 Questions View all
Will Apple repair my MacBook?
Will Apple service my Macbook?
I got a 5 months old Macbook pro 16" and I accidentally spilled juice on it today. I immediately flipped it over and turned it off. Then I started opening it to unplug the battery.
Unfortunately I punctured the battery while doing so and now the battery is damaged.
Will apple service the machine at all? Or will they not accept it?
1 Comment:
Apple does repair water damage and battery replacements so they might fix it.
by
Add a comment
1 Answer
mmm... This is a tough question as Apple won't fix your system under warranty if that was what you where hoping for between the liquid spill and the damaged battery. Apple may even refuse doing the repair as they often do for liquid damaged systems.
I would recommend you find a good independent Mac shop nearby to let them check things out they would more likely be cheaper that Apple.
Add a comment
Add your answer
Mohamed Alnahhas will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 2
All Time: 41
