The HTC EVO is a Smartphone by HTC powered by a 1-GHz Snapdragon processor and runs the Android operating system.
92 Questions View all
How much for new charger port?
just started having problems charging my evo 4g, then when i took a closer look i noticed that one of the terminals in the port had snapped off. My cell will still charge but i have to force the charging cable to face down and have applied waight to the bottom of the port, affriad temporary fix won't last much longer.
Add a comment
1 Answer
Chosen Solution
rockybrett, here is my answer from another question "I believe that the EVO 4G uses a standard micro USB connector. The pinout is as follows
Pin Name Description
1 VCC +5 VDC
2 D- Data -
3 D+ Data +
x This pin may be connected to GND for cable detection.
4 GND Ground
Pin 1 is the far left when you look straight on. So pin 1 and pin 5 would be my choice to charge. " Use these guides to get to your logic board HTC Evo 4G Repair and the port is available at places like this. There are a couple decent videos on youtube, like this, that may help you to determine if you are up to it. Hope this helps, good luck.
Score 2
Add a comment
Add your answer
rockybrett will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 1,126
