Apple's October 2020 refresh of its iPad Air tablet, sporting an A14 Bionic processor, a 10.9" screen, a new design, and in-button TouchID.
iPad Air 4 anti-repair measures
Are there any anti-repair boobytraps in this device? Touch-ID of course is probably coupled with logicboard I'm going to assume..
What about the screen for example though? Does swapping the screen with replica variant cause true-tone to disable?
Add a comment
1 Answer
Most Helpful Answer
Hi
This is a really good question HOWEVER…
Unfortunately people haven’t really tried looking for any anti repair traps so they are basically unknown but I can give you some information on what to expect and lookout for:-) (just from my experience from Apple products in general!)
When lifting up the screen be careful of the short screen cables as if you aren’t careful you can rip the connector off the board
Remember to disconnect the battery to prevent any damaged to components
Expect True Tone not to work (might work if the screen data is transferred over with the correct equipment)
Expect a “screen not genuine” message after the new screen is installed
And last but not least expect LOADS of adhesive as that’s what majority holds iPads together
If you have any more questions please ask;-)
Hopefully this helps
Score 2
3 Comments:
Thank you for all this useful information. I've fixed many devices before and I'm aware of common obstacles. However I need some hard facts specifically about this device. Is the screen locked to the logicboard (for true tone)? Someone who has worked on this device probably knows the answer for sure.
by
@capacitor
Ok sounds good
Maybe try looking on YouTube for tutorials as they might mention the pairing issue:-)
by
Hello, I just replaced my logic board into another ipad and I can tell you about the anti-repair tactics that my ipad has. True tone still works even though everything in the ipad is replaced, and there are no “non-genuine” messages. What there is though has something to do with the apple pencil, as after i replaced the logic board the apple pencil is a bit squiggly when you write on it, it didn’t happen on my old ipad. Hope this helps!
by
Add a comment
Add your answer
Sam will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 9
All Time: 326
