Changing USB-C port - can't clear port holes.
Hi,
I am following a number of different tutorials on how to change the USB-C port on a switch and i am halfway there.
I've successfully removed the old port and now i am in the process of clearing out the old solder from the circut board. However, it doesn't want to come out, i've tried reapplying more solder and then use solder wick. I've tried heating the location up with hot air and get some solderwick down there.
But to no avail, i could buy a solder sucker but i think its a bit overkill since i wont be doing this kind of repair again very soon.
Anyone with any tips?
Maybe while the solder is flowing, put something in there?
1 Comment
@tech_ni This was the state of the circuit board before I put the new port on.
I added new solder and made sure it was clean for the attachement. Flux in loads and alot of heat.
[image|2693237]
I have a multimeter, I'll check between some points. But I might need a new port then, all this reworking might have turned a relatively easy job into a mess.
by the_ogge
