iPod Classic 6th Generation. Model A1238 / 80, 120, or 160 GB hard drive / black or silver metal front
903 Questions View all
Error message 1430 appears when trying tho restore the iPod
When trying to restore ipod settings error message 1430 appears. Have tried all suggested resolutions to no avail. Any suggestions?
Score 2
3 Comments
it might be a good idea to explain what you did. i would try to restore it in disk mode....
by
I am with markus weiher on this. Place the iPod in disk mode and format the iPod. Then restore and resync with itunes.
by
I have a mac. How would one do this on said mac?
by
Add a comment
1 Answer
Chosen Solution
Peter Pettit, just in case you are on XP you might want to look into this as well. " Causes:
The causes responsible for the above error messages is the digital signing of Windows XP drivers.
Resolution:
The resolution to the above error message restore the iPod using latest version of iTune. If you are unable to fix the problem with this step, perform the following procedures:
  • Disconnect the iPod from your computer and close the iTunes
  • Highlight all the following texts which has regsvr32 as the beginning text
regsvr32 /s softpub.dll
regsvr32 /s wintrust.dll
regsvr32 /s dssenh.dll
regsvr32 /s rsaenh.dll
regsvr32 /s gpkcsp.dll
regsvr32 /s sccbase.dll
regsvr32 /s slbcsp.dll
regsvr32 /s mssip32.dll
regsvr32 /s cryptdlg.dll
regsvr32 /s initpki.dll
Click on the Copy option from the Edit menu of your web browser
  • Navigate Start > All Programs > Accessories > Notepad to reach the Notepad program
  • Choose Paste from the Edit menu from the Notepad option
  • Select the Save As option from the File menu
  • Type appleipod.bat as the File name and save the file on the desktop
  • Close Notepad and locate the appleipod.bat file
  • Double click on the file. A black screen appears within a minute. Wait till the black window disappears and then follow the next step. This will delete the appleipod.bat file
  • Open iTunes and connect the iPod
  • This would lead to appearance of iPod in the iTunes. Restore the iPod and synchronize the content" From here Hope this helps, good luck.
Score 2
Add a comment
Add your answer
Peter Pettit will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 21
All Time: 7,899
