Memory module 1, heatpipe input and output temperature 128 and ts0p
Hi i have an old mid 2012 a1278 md101,
I have high CPU usage and fans at full speed. Checked with hw monitor the memory module 1 and heatpipe incoming and outgoing air temperature is 128 degrees Celsius which is definitely incorrect. On running ASD EFI it shows ts0p sensor failed - SMC I/O failed.
I would like to know how to fix this, I can resolder if needed and have a donor board but how is palmrest/trackpad sensor related to the memory module and heat pipe sensors.
Update (06/18/2022)
Adding TG pro screenshot
Also i have cleaned the entire board and could not see any signs of water damage. Post that cleaned the board with IPA and a brush.
Update (06/19/2022)
installed a spare battery i had.
