Fourth generation iPhone. Repair is straightforward, but the front glass and LCD must be replaced as a unit. GSM / 8, 16, or 32 GB capacity / Model A1332 / Black and White.
3238 Questions View all
iPhone 4 won't swipe after replacing front screen.
Just replaced my front LCD/Glass of my iPhone 4 and I cannot swipe to unlock! I cannot even swipe to turn off the phone, but I can hit "cancel" when trying to power it off so it seems like my screen does respond to touch...SO WHAT'S WRONG WITH IT?! Could someone please help?
Score 1
Add a comment
Chosen Solution
The first thing I recommend doing is checking all the connections to make sure everything is plugged in correctly.
If your original front screen is only cracked, then you could swap it back onto the iPhone to see if the touch works on the original from panel.
If the new panel is plugged in correctly, but doesn't work, and your original panel still works, then contact the company you got the front screen from and ask for a replacement. Hope that helps!
Add a comment
If the connection is correct then the screen is faulty or you have pinched the cable they are soso fragile
Add a comment
Add your answer
Scott Clizbe will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 11
All Time: 3,830
