Can this "disconnecting" keyboard be fiexed?
For a little over a year now, My MBP has been having this issue. While in normal use, the keyboard and track pad will become inoperable (When in windows, the sound of a usb device being disconnected occurs). I found out that if I press on the area left of the track pad, the keyboard will reconnect.
I have considered this a minor annoyance up until a few days ago where the the keyboard/trackpad wont work unless I hold on to the aforementioned area. Is this even fixable or should I just sell this MBP for parts and get a new laptop?
Add a comment
1 Answer
Chosen Solution
This fault is well known. The little USB controller on the PCB under the trackpad is failing / desoldering. It's the square chip visible when you remove the battery. There are basically three methodes to remedie / solve this:
- cowboy: fold a piece of paper and pich it between battery and chip.
- homebrew: Take a small tip soldering iron and retip all the solder joints ( magnifiere required)
- luxury: replace the topcase.
Score 2
Add a comment
Add your answer
Alex Satterlund will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 274
