Fourth generation iPhone. Repair is straightforward, but the front glass and LCD must be replaced as a unit. GSM / 8, 16, or 32 GB capacity / Model A1332 / Black and White.
3239 Questions View all
Why wont my phone recives any signal?
After a hard fall my iphone on sparadicly recives any sort of signal, 3g or network. What would be the most likly cause of this?
Comments:
Seeber, can you tell us which iPhone you have?
by
i have the iPhone 4 first gen.
by
Add a comment
Chosen Solution
Two main reasons this has happened
- Loost antenna connection due to impact force
- Damaged logic board
If the antenna has become loose, all you will need to do is remove the back cover and re-seat. If the logic board has been damaged then you will need to take your phone to apple and request for a replacement.
Score 2
Comments:
usually a loose antenna
by
Add a comment
you can change your sim card and try it .if that your cellphone doesnt work ,maybe it was broken.
Add a comment
Add your answer
seeber will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 752
