There are so many things we could do if we only knew how. This area aims to catalog most specialized skills necessary to perform certain kinds of repairs.
216 Questions View all
How can I easily remove the bits from a 26-bit kit?
If you're anything like me, your fingers aren't needle-nosed pliers. I struggled to remove the tightly-packed bits until I wrapped a rubber band around it and then easily pulled it out. Now whenever I open the kit up, I make sure to have a rubber band nearby so I can quickly and easily get to the bit I need.
Score 1
Comments:
Asked and answered myself. Mainly here in hopes someone else might benefit from the little tip.
by
aaronmiller, it's really not a repair related question ;-) but most certainly a great idea. I think you should take a couple of pictures and create a guide to have it posted on ifixit. http://www.ifixit.com/Guide/new I think that would be very helpful and a neat little guide to have.
Split your original question. Create one true question, and post your tip as an answer. You can even accept your own answer....:-)
by
Add a comment
New Battery = Faster iPhone
Fix Kits starting at $16.99
Chosen Solution
Thanks for the advice oldturkey03 :D
Here's that: iFixit 26 Bit Driver Kit Technique for Removing Bits
Score 1
Comments:
Thanks Jamy, I tried this...handy when you don't have a rubber band around, but with a rubber band, it's even easier.
by
Add a comment
I always put the handle over the bit I want to remove, pull outwards and then upwards, remove the bit from the handle, turn it around, put it back in, and presto :)
Add a comment
Add your answer
aaronmiller will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 539
