Water fills up then shuts off
Washer Weill fill up with water then shuts off does nothing
There is already an answer to the issue here: Whirlpool Dishwasher stops after filling with water
You can also check the wash motor for the continuity, this is how to check it:
Disconnect all power to the dishwasher by flipping the appropriate circuit breaker
Locate the motor which should be behind the lower kick plate or access panel
This panel will be secured by either two or four screws, remove all of them so the panel comes all the way off
On some dishwasher models, you must open the door to remove some screws. Just be sure to close the door before removing the panel
Disconnect the two wire leads from the wiring harness that are attached to the motor
Using a multimeter, set the device to R x 1.
Touch each of the multimeter’s probes to one terminal each
The motor should show very little resistance, such as a reading of zero or close to it
Also check the ground connection by placing one probe on the bare metal housing of the motor, and the other on each terminal (one at a time)
This test should show no reading on the meter
If either of these tests shows readings other than what they should, then the motor is bad and needs to be replaced.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 26
2 Comments
Do you have any more information, does it give an error when this happens? Or something else that seems like it isn't as it should be? If so, please add that information to make it possible to help you further.
by Erik Eriksson
Hi,
What is the model number of the washer?
by jayeff
