Second generation of iPhone. Model A1241 / 8 or 16 GB capacity / black or white plastic back. Repair is more straightforward than the first iPhone. requires screwdrivers, prying, and suction tools.
1497 Questions View all
any solution for the 23 error?
exist any solution for this problem? i have an iphone 3g with this problem (error 23). have i change the battery?
Add a comment
New Battery = Faster iPhone
Fix Kits starting at $16.99
1 Answer
Chosen Solution
I would definitely start with a new battery. MAke sure you get a 3G compatible one. It is POSSIBLE that this causes the error. You might want to try a search on Error 23 on here. I also recommend you look at I phone wont turn on.Error 23 after battery drained! azusbear on I cant restore error 23 says he found a solution as well. My suggestion would be to start with a new battery and go from there. Hope this will get you started.
Score 1
Add a comment
Add your answer
Jhon alexander Latorre garcia will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 351
